FlowPaw goes wireless with Bluetooth
Interested in the Internet Of Things (IoT) then use a Bluetooth Claw with FlowPaw and go wireless!
Here we have made a rover that can be controlled via FlowStone, in the beginning we use an Xbox controller to drive the rover around, then switch to Autonomous Mode and let the rover drive itself using IR distance sensors to avoid obstacles!
All of the decision making (code) runs on the Laptop so you can literally edit the code as it drives around!
One thought on “FlowPaw goes wireless with Bluetooth
  1. “All of the decision making (code) runs on the Laptop so you can literally edit the code as it drives around!”
    You guys should take the FlowPaw to the hospital. It’s way too sick!
    Seriously though, this is another great example :-)
    I have a question about the rover. Is it available for purchase already? If not, then are there any plans of making it available?
    It’s just that this example is so cool that I’d like to do it myself too :D
    Thanks for everything :-)
Leave a Reply
Your email address will not be published. Required fields are marked *
You may use these HTML tags and attributes: <a href="" title=""> <abbr title=""> <acronym title=""> <b> <blockquote cite=""> <cite> <code> <del datetime=""> <em> <i> <q cite=""> <strike> <strong>
