New Final Production Boards Arrive!
We just received the first batch of the full production boards this week!
FlowPaw Rev 1.01
These are the Rev 1.01 PCB’s with the slightly modified expansion connector:
FlowPaw Connector
We made these with a 10 way header so it works with standard ribbon cables and also added a 5V & GND header so that you can power the board from an external 5V source or use the 5V for external sensors if necessary.
One thought on “New Final Production Boards Arrive!
Leave a Reply
Your email address will not be published. Required fields are marked *
You may use these HTML tags and attributes: <a href="" title=""> <abbr title=""> <acronym title=""> <b> <blockquote cite=""> <cite> <code> <del datetime=""> <em> <i> <q cite=""> <strike> <strong>
