X10 Home Automation
Home and building automation using flowstone
admin
Site Admin
X10 Home Automation
Post by admin »
FlowStone now supports X10 home Automation!
Check out the Marmitek CM15 Pro USB Home automation Interface!
Turn lights on and off, close curtains, open garage doors, home security, you name it!
Available in FlowStone FREE release today!
There are some simple examples to get you going here:
Lamp On/Off Test:
http://www.dsprobotics.com/support/viewtopic.php?f=11&t=82
PIR Test:
http://www.dsprobotics.com/support/viewtopic.php?f=11&t=83
Embedded
Re: X10 Home Automation
Post by Embedded »
That's cool!
So using FlowStone I can now make a complete home automation system!
paul.pacini
Home Security Application
Post by paul.pacini »
Besides home automation, given FlowStone’s I/O capability and low computing overhead, you could make one heck-of-a home security system with an old PC and some X-10 modules. Besides doing all the usual door and window checking, it could also have some built-in redundancy to avoid false alarms from pets. It could look for motion changes with cameras and send images to the owner via email or SMS. It could switch lights on and off for a “lived-in” appearance.
Wow, that just gave me some cool ideas… :idea:
Kind regards,
Paul
____________________________
To err is human; to blame problems on external factors is even more so.
Embedded
Post by Embedded »
I have this Home automation kit now and it works great with FlowStone.
I've made it so that I can turn the lights on or off using a IR remote control and the Phidgets IR Remote Control Interface & the Marmitek CM15 Pro USB Home automation Interface:
Phidget IR 1055
Phidget IR 1055
Phidget IR 1055.jpg (20.34 KiB) Viewed 389042 times
CM15 Pro X10 Controller
Hales
Post by Hales »
X10 is a protocol for communication among electronic devices used for home automation (domotics). It primarily uses power line wiring for signaling and control, where the signals involve brief radio frequency bursts representing digital information. A wireless radio based protocol transport is also defined.
Baku Business Visa for Pakistani Citizens click here
