LynxMotion Mini Terminal
A wide range of example files that you can load up in FlowStone
admin
Site Admin
Post by admin »
In this example you can directly type the servo commands into a terminal window for the LynxMotion SSC-32 board.
Example:
#0 P1500 (Set servo 0 to pulse width 1500 = center)
VER (Request firmware version)
VD (Request the A/D I/P 'D' level)
LynxMotion Mini Terminal.fsm
LynxMotion Mini Terminal V2
(10.39 KiB) Downloaded 4643 times
