Ruby Knob fully customisable
here is a fully customisable rubyknob.
latest version:
latest version:
- ruby_knob_3_001.fsm
- (3.25 KiB) Downloaded 1151 times
- TheAudiophileDutchman
Re: Ruby Knob fully customisable
thx for sharing NuBeat, maybe i understand that Ruby stuff a little bit more when i have a look at your work and how
you made this knob...
philton wrote:thx for sharing NuBeat, maybe i understand that Ruby stuff a little bit more when i have a look at your work and how
basically i tried the things which you can find in the FS userguide, all the grafic stuff is written down there with examples...
unkargherth
A ittle update. Made it still more configurable ( Sky is the limit ! )
Changelog inside
Changelog inside
Free your memory, .. with a free(). Like a pointer
Cast a pointer into an integer and it becomes the integer...
Cast a pointer into a struct and it becomes the struct...
A pointer can overflow... or can crash...
Be a pointer my friend
Great work, guys - this is just what FS3 needs now, a big selection of cool user modules so that folks get a good choice of different 'looks' etc., and stuff to learn from.
And I always preferred the knobs with a sweep arc - I find them so much easier to read at a distance.
unkargherth wrote:A ittle update. Made it still more configurable ( Sky is the limit ! )
Changelog inside
great update unkargherth, its so much cleaner inside now, also the properties are much better readable with more things to do, thanks for this!
How to hide and hold the mouse pointer when turning the knob?
unkargherth
I understand about hide.. but can you explain in detail what is the "hide and hold" behaviour ?
Hold is where, when the cursor 'unhides' it is still in the same place where clicked - so changing the control does not move the pointer position, and it is easy to find when you let go of the button.
