OS version module
DSP
OS version module
Post by DSP »
Anyone know how to tell what OS your exe is running on (XP or Win7 ?)
fixstuff555
Re: OS version module
Post by fixstuff555 »
GetVersionEx API? Is this available to add in Flowstone? the dwmajorVersion and dwMinorVersion can display windows version...
Morph
Post by Morph »
Here's a solution although it is not thoroughly tested.
OS_finder_Mo.fsm
(1.5 KiB) Downloaded 1079 times
Embedded
Post by Embedded »
Here's some Ruby code that seems to work:
OS Version.fsm
(274 Bytes) Downloaded 1064 times
DSP
Post by DSP »
thanks all, that should get me going...
Might someone expand out the 1st example [using PRIMS] to include Win 8 ???
OS_finder_Mo.fsm
thanks
Mo
Post by Mo »
Here is an update. I have not tested it with Windows 8 yet.
OS_finder2_Mo.fsm
(1.54 KiB) Downloaded 1037 times
Hi MO !!!
Where ya been ?? Hope all is well !
But not so well with this update unfortunately :| This one doesn't identify mine. The field is blank, the internal selector pointing to 1st S position [no input connection].
Mo
Post by Mo »
Yep, hope to have more time for FS soon.
Ok, maybe it was optimized too much. Here's a new update to try.
OS_finder3_Mo.fsm
(1.56 KiB) Downloaded 1051 times
Three is a charm ... at least on XP :D
Thanks MO ... maybe guys with the new-fangled OS's will give it a running report.
confirm: Win XP
Hope you find time MO !!
Thanks 8-)
