array from text
array from text
i have several lines of text, separated by end of line (enter) in flowstone text module.
can i turn each line to an array string value?
Re: array from text
yes m8 you just attach your txt to the assign input on whichever array type you are using and read out the lines you want with a get at primitive
ive attached an example
Re: array from text
oh thanks Jay, just saw your answer. (maybe this "Notify me when a reply is posted" should be on by default)
i solved it using this in ruby:
is any solution better than the other?
a = @text.split("\r\n")
output "array", ais any solution better than the other?
Re: array from text
Under high load in ruby routines within schematic - ruby may shut down. Greens are more stable. Plus - if your schematic contains hunderts of ruby modules - the schematic may get slower in some aspects.
But I guess in your case - it's a matter of taste.
