Rubygems
sal
Rubygems
Post by sal »
any chances to add rubygems support?
Thank You
Sal
DSP
Re: Rubygems
Post by DSP »
It already supports Ruby Gems!
sal
Re: Rubygems
Post by sal »
how?
I tried the ruby way without success
sal
Re: Rubygems
Post by sal »
gem install mysql
gem install sqlite3-ruby
gem list
how do i accomplish this ?
mr DSP how do you install and use gems?
infuzion
Re: Rubygems
Post by infuzion »
sal wrote:
gem install mysql
gem list
How do I accomplish this ?
Have you tried to install the gems manually?
http://docs.rubygems.org/read/chapter/3
sal
Re: Rubygems
Post by sal »
yes i tried that, but at the moment the use of gems is not allowed as confirmed by dsp robotics on pm due to bugs caused by gems on windows platform.
Hope they will find a solution at least for adding database connectivity and network usage.
infuzion
Re: Rubygems
Post by infuzion »
Oh, OK, cheers.
Embedded
Re: Rubygems
Post by Embedded »
Sal - here's the workaround to get Gems working inside FS.
As said before many of the Gems will not work on Windows!
FOR ADVANCED PROGRAMMERS ONLY!!!
Step 1) Install Ruby on your PC
In order for this to work it needs to be a mswin32 compiled version of Ruby not a ming32 version.
Try this: http://www.dsprobotics.com/Files/Ruby192MSwin.zip
Just copy the folder to somewhere on your PC, you can also have the ming32 one installed in a different folder.
Check: Ruby -v
Should say something like: i386-mswin32
Step 2) Create a shortcut on your desktop
Right click - shortcut etc.
Use this string: C:\WINDOWS\system32\cmd.exe /E:ON /K D:\Ruby192MSwin\bin\setrbvars.bat
but remember to modify the path to match your ruby installation.
Step 3) download Install Gem on your system:
Put the downloaded gem in the gem folder: D:\Ruby192MSwin\lib\ruby\gems\1.9.1\gems (using your own path)
then in Ruby:
gem install gemname
You should see the gem install:
Gem Install.png (5.55 KiB) Viewed 41126 times
Step 4) Add the new path to FlowStone's ruby
Open FS2 and enter something like this into a Ruby edit module:
$LOAD_PATH << "D:/Ruby192MSwin/lib/ruby/gems/1.9.1/gems/myGemFolder"
Remembering to use / not \
This only has to be done once!
Step 4) Test Gem
Start with a new Ruby Edit module and test if it loads:
ie. require 'MyGemName'
Results: the first time it load you get a result of True, from then on False - both are good it has been loaded!
Ruby Gem Test clip-2.png (5.39 KiB) Viewed 41126 times
If the loaded gem causes a crash then it is the gem that doesn't work on Windows NOT FlowStone!
Thanks 'DSP' for you help on this..
DSP
Re: Rubygems
Post by DSP »
Embedded - You're welcome, glad I could help...
Also worth mentioning is that gems are all the rage, but on Windows dll's have been doing these things for years.
dlls work perfectly with FlowStone V2 & Ruby on Windows, so if you have any specific need it's probably more reliable to just make a call to the dll.
Tronic
Re: Rubygems
Post by Tronic »
i have already tested this but for example this simple sock call
require'socket'
#Socket.ip_address_list
Addrinfo.udp("192.168.0.2", 10001).bind {|s|
  p s.recv(10) #=> "hello"
stop the ruby code
""Execessive processing detected...etc.etc"
and even this
require 'Win32API'
getForegroundWindow = Win32API.new('user32', 'GetForegroundWindow', 'V', 'L')
window_handle = getForegroundWindow.Call()
getWindowText = Win32API.new('user32', 'GetWindowText', 'LP', 'I')
title_buffer = ' ' * 512
getWindowText.Call(window_handle, title_buffer,512)
title_buffer
but the oddity is that, by removing the buffer size, working
getWindowText.Call(window_handle, title_buffer)
title_buffer
