Buffers
Rocko
Buffers
Post by Rocko »
Hi all,
I'm trying to run a simple buffer, using arrays ('DSP code module'), without success.
It seems like a simple syntax issue... Could you help?
What am I doing wrong?
monoin in;
monoout out;
float buffer[2];
out = buffer[0];
buffer[0] = buffer[1];
buffer[1] = in ;
Thanks
Re: Buffers
That's a limitation of FS's array implementation: you can't use different array elements in one equation. :-(
Your example would work with a termporary - uhm - buffer (temp variable):
monoin in;
monoout out;
float buffer[2];
float temp;
out = buffer[0];
temp = buffer[1];
buffer[0] = temp;
buffer[1] = in ;
But that's of course kinda pointless. When using arrays, you do not want to move the data like in a fire brigade. Look inside the stock delay, there is a ring buffer.
Rocko
Re: Buffers
Post by Rocko »
Thanks Martin - appreciated !!
