Stereo width control
blatantleesly
Hi all,
A simple stereo width control using DSP.
Re: Stereo width control
Thank you, I'll make use of it.
To all asm-gurus: Is this already as fast as possible, or could one of you optimize the asm code?
there is a minor bug in the code:
The signs should be swapped, because mid=left+right and side=left-right => left=mid+side
here is ASM optimized version of the code:
the CPU savings will be minuscule though - the code is only using + - * which are very CPU cheap and those few intermediate variables don't make much difference.
out1 = mid - side;
out2 = mid + side;
streamin in1;
streamin in2;
streamin width;
streamout out1;
streamout out2;
float x=0.5;
movaps xmm0,width;
mulps xmm0,x;
movaps xmm0,in1;
movaps xmm1,in2;
movaps xmm2,xmm0;
addps xmm0,xmm1;
subps xmm2,xmm1;
movaps xmm3,x;
mulps xmm0,xmm3;
mulps xmm2,xmm3;
mulps xmm2,width;
movaps xmm1,xmm0;
addps xmm0,xmm2;
subps xmm1,xmm2;
movaps out1,xmm0;
movaps out2,xmm1;the CPU savings will be minuscule though - the code is only using + - * which are very CPU cheap and those few intermediate variables don't make much difference.
Will test it later, but wanted to already thank you.
From theory side, can't this code be optimized by SSE, meaning by packing L+R into a single SSE, then processing SSE(0) and SSE(1), and then unpacking?
Or is that true only if running the same exact processing on both Left and Right inputs, which is not the case here?
