Color Designer + Color Mod
I made a small dev tool for creating and tweaking colors with a graphic interface without having to rely on the Windows picker. Notably, it switches seamlessly between HSV, HSL, and RGB color modes.
I'm planning to create a related tool next, but I figured I'd look for feedback on this first, since it will be similar. Hopefully I didn't leave any loose ends (it is a bit hairy on the inside). But let me know what you think or if you find any problems.
EDIT: Version 1.1 now includes working color banks.
EDIT 2: Added new module: Color Mod
This adjusts an input color by adjusting the component values. Also supports HSV, HSL, and RGB color modes.
- Color Mod 1.1_PHI.fsm
- (16.66 KiB) Downloaded 1269 times
- Color Designer 1.1_PHI.fsm
- (40.51 KiB) Downloaded 1254 times
Last edited by Perfect Human Interface on Thu May 14, 2015 11:51 pm, edited 3 times in total.
Re: Color Designer
its cool that it includes the HSL too (didn't knew it does exist or how it defines the colors
could be a good extension for tiffy's colordesigner where i did the color table for - it also shows / lets you edit, the colors in hexcolor format and it has a coulour picker too..
viewtopic.php?f=3&t=1839&start=30#p9124
Re: Color Designer
The HSL conversions were from "mwvdlee" on the Synthmaker forums, in his "missing links" toolkit (which contains a bunch of pretty cool stuff).
http://synthmaker.co.uk/forum/viewtopic ... &sk=t&sd=a
HSL is actually really useful for graphic stuff and it's what the Windows picker uses.
That color picker you linked actually reminded me I was going to, and entirely forgot to, add a few "banks" to this tool. It will make the interface bigger but I'll probably do that next.
Re: Color Designer
Updated, see first post.
Re: Color Designer + Color Mod
Added new module: Color Mod (see first post)
My intention was to make this module work efficiently even for real-time changing color input, but note that it puts out 4x the triggers as the input, and I don't know of a way to fix this since trigger blockers and sample and holds don't work with color links.
These were the two tools I planned to make. Please let me know if you find any problems.
Minor update: just added some inputs to the color mod so the parameters can be controlled externally.
