Help with ADSR multiplexing (solved)
jackmillarnz
Post by jackmillarnz »
Hi there! i am pretty new to this compared to most of you im assuming so please don't judge my lack of knowledge :D
I am trying to figure out how to create an ADSR module that i can route to different OSC pitches as i choice in the GUI.
I have created an ADSR and connected it to a multiplexer, but my question is where to send the outputs, i tried setting a stream multiply in between my detuner and the oscillator, but then when i disable the ADSR or send it to a different place, the output from that oscillator mutes. :evil:
Any help would be greatly appreciated!
Thanks.
Jack.
Drnkhobo
Re: Help with ADSR multiplexing
Post by Drnkhobo »
Thats because you are multiplying a stream by 0....which makes it 0. You need to have another multiplex to add either 0 or 1 to that input again depending on the multiplex state.....
take a look:
Schematic1.fsm
(27.48 KiB) Downloaded 791 times
jackmillarnz
thank you! that makes sense :D
i have it working as it should now.
Drnkhobo
Re: Help with ADSR multiplexing (solved)
Post by Drnkhobo »
Sumeraxe6
Post by Sumeraxe6 »
I made this in ruby, which greatly facilitates the entire management.
For any questions please do not hesitate to ask.
Sumer
