Restricting input in edit box?
- Subquantum
Can someone tell me if there is an easy way to limit the amount of characters entered into an edit box? And if so, can there also be a distinction between only accepting numerical vs alphabetical characters?
Re: Restricting input in edit box?
Hi
Here is an example of restriction by blocking the output and send a trigger to start if it exceeds the limitations. You can find the restrictions in the module properties.
- Restricted Edit Box.fsm
- (1.35 KiB) Downloaded 692 times
- Subquantum
Thanks Mo!
Looking at these examples really helps me to learn how to work with these graphical components beyond what is available in the manual.
