Sample Recorder Schematic
glitchcpt
Post by glitchcpt »
Hey Guys :)
Just want to say, please excuse the noob work in this schematic, i'm still learning, and a lot of the stuff is made up of elements I have found on this forum, and I changed them a bit.
I am trying to get this schematic to record the input straight into the sample loader, without having to save it and load it in between? I wonder if that is even possible?
Also I am trying to link the Pitch (Green - Float) onto and LFO (White - Poly), any suggestions would be great
SAMPLE RECORDER1.fsm
(242.15 KiB) Downloaded 1246 times
Re: Sample Recorder Schematic
Yes, you can. Simply connect the wave connector from mem-create prim directly to wave player (to the interpolated read module).
EDIT: in order to make it work with loaded files too, you will have to use selector to switch between loaded wave file and mem-create wave.
As for the pitch. It should work to directly connect green to any stream - be it blue or white.
glitchcpt
Post by glitchcpt »
Thanks KG!! :mrgreen:
Let me try if it works
I usually get it working Green - Poly, but in this instance its the other way round, Poly - Green, is there a way of capturing the data in bits, into a float? (excuse me for not explaining it very well)
There is poly to array prim that may be able to do this. it captures first 2048 samples from each voice or something. I never used it though.
glitchcpt
Post by glitchcpt »
Ok! Thanks man, it seems to work with the M2F primitive :)
I can't manage to get the sampler record function to work yet tho
Sumeraxe
Post by Sumeraxe »
This is exceptionally decent and wonderful post.
I am very happy joined this forum.
I like it exceptionally much....!!!!
Thanks alot...
Sumer
