Hilbert Shifter
Hilbert Shifter
A Hilbert shifter creates two signals with a relative phase shift of 90 degrees for all Fourier components in the audible range. It can be used for e.g. single-sided modulation or frequency shifting. As opposed to pitch shifting, frequency shifting alters harmonic overtones so the result may not always sound musical. :mrgreen:
This Hilbert shifter is based on Tronic's coefficients calculator. 8-) It is rather high quality: covered range is from 30 Hz to 22 kHz (at 44k sample rate), sideband suppression is around 90 dB. However, the implementation is optimised so the CPU load is not at all critical.
Merry Christmas!
MV
HilbertShifter.fsm
(101.81 KiB) Downloaded 2000 times
Last edited by martinvicanek on Wed Dec 24, 2014 12:20 pm, edited 1 time in total.
MyCo
Re: Hilbert Shifter
Post by MyCo »
Dammit, crashs 3.0.7 immediately.
EDIT: Not related to 3.0.7, happens in 3.0.6 as well
steph_tsf
Re: Hilbert Shifter
Post by steph_tsf »
I'm on Win7 now.
I faced the same instant crash when double clicking the .fsm.
There is no crash when opening Flowstone, then "File" then "Open".
Nice piece of art, indeed.
What kind of instructions are : fld a00[0]; fstp a1[0]; fld a01[0]; fstp a1[1];
Say I build an envelope detector using the sqrt(sin^2 + cos^2) identity.
Will I get a proper result, knowing that both sides (odd and even) get phase-shifted, hence time-domain modified?
many thanks,
and happy Christmas,
Steph
Tronic
Re: Hilbert Shifter
Post by Tronic »
THX...
MyCo
Re: Hilbert Shifter
Post by MyCo »
Weird, as Steph wrote, loading it from within FS doesn't crash.
fld x[y] loads a float value from x (sse channel y) on a stack
fstp x[y] stores the latest stack value into x (sse channel y) and removes it from stack
Re: Hilbert Shifter
Ouch, that's bad. No problems here, though. :? I am still with FS 3.0.3. No backward cpmpatibility? :(
P.S. I had forgotten to eliminate denormals in the original schematic. :oops: Fixed now.
Re: Hilbert Shifter
Is it possible to create an allpass filter with 90° phase shift form the original signal?
I know Nyquist and DC components can't get phase shifted, but perhaps if the filter was also HLP/LPF to remove these elements. It would be very useful in phase-alignment tools (making 0-360° phase shifter).
Re: Hilbert Shifter
KG_is_back wrote:90° phase shift form the original signal
Yes, you can do that with a FIR filter, however at the cost of more latency and much more CPU load.
Re: Hilbert Shifter
Confirming. DbClick on schematic - crashes Flowstone. Opening schematic from within Flowstone - opens it normally. Some initialization problem was probably introduced in FS. Sent to Malc.
cbbuntz
Re: Hilbert Shifter
Post by cbbuntz »
Are you using the same filter structure that Olli Niemitalo used? I tried plugging the coefficients into an existing allpasses and it didn't work. I'm having trouble deciphering the code.
The performance is very impressive.
