generic "virtual" comport
fixstuff555
Post by fixstuff555 »
Here is a "remote" comport. Basically on the server side program, a COMport primitve is interfaced to the Ethernet Server primitive, and on the Client side is strictly the Ethernet Client. Although not a true virtual comport, it allows an easy way to write messages to a comport located on a remote computer, and receive replies. I tested it with a simple loopback, but it probably needs a bit more work to fully flesh it out. By adding another COMport primitive on the Client side, you would have a basic tunneling serial port. Both features if purchased in a specialty module usually runs from $150 to $500 for full blown virtual serial ports with tunneling (i.e Digi IAP one or similar). With a bit more work, this code could become VERY useful to someone possibly.
virtual comport_server_r1.fsm
(15.18 KiB) Downloaded 1979 times
virtual comport_client_r1.fsm
(14 KiB) Downloaded 1931 times
