Toggle and Flip-Flop module
arend
Post by arend »
Simple but useful, why are not listed as primitives ?
Toggle: alternates the logic output after each trigger.
toggle.fsm
Toggle
(291 Bytes) Downloaded 2204 times
Flip-Flop: a logic memory, with set and reset
FLIPFLOP.fsm
Flip-Flop
(413 Bytes) Downloaded 2162 times
Morph
Re: Toggle and Flip-Flop module
Post by Morph »
You can find something similar in the switch. Also the last "Not" in the toggle seems not to be needed.
Cheers.
arend
Post by arend »
The last '"NOT" is just for initializes the output module w/ "0'" logic.
brgds
DSP
Post by DSP »
Here's an alternative Flip-Flop that is simpler and safer.
FLIPFLOP-2.fsm
(535 Bytes) Downloaded 2115 times
arend
Post by arend »
DSP,
Understood, tks !
brgds
fixstuff555
Post by fixstuff555 »
DSP wrote:Here's an alternative Flip-Flop that is simpler and safer.
Um that's coming up as a newer version than mine which is 1.1.5. Is there a version newer than that?
DSP
Post by DSP »
fixstuff555 wrote:Um that's coming up as a newer version than mine which is 1.1.5. Is there a version newer than that?
Indeed, I am also a beta tester!
fixstuff555
Sweet... Can't wait to see it!
