ADSR Bug
Posted: Thu Sep 04, 2014 5:18 pm
Hi folks, I'm currently having some trouble with the stock ADSR module (the graphic one). I had basically wired it up to my poly streams using multiplexers and a switch to act as a bypass. I found out that my project was not sounding right, and I traced it back to this ADSR module.
So here's the weird stuff. Even when bypassed, the module effects the audio. I put poly readouts on the inputs and the outputs and they all read zero, with the exception of the "envelope" output, which was putting out data (so the module was at least still reacting to poly streams, although this output was not connected to anything). Even once I start disconnecting the module's input the issues persists, up until I pull off the last connection on the output, then things would go back to normal.
So in short, the module is inappropriately effecting poly streams even with nothing connected to the inputs as long as the output is connected somewhere (even though the output is reading zero).
Testing now it also happens with the other ADSR module (the knobs only one, which uses a DSP code block instead of the ADSR4 primitive).
Does anyone know what the heck this is all about? My project requires ADSR.
