Ultimate Ticker (Unlimited Ticker)
If I am correct, this should be unlimited ticker.
NOTE: Triggers per second need asio out inside project, or audio out if you are inside FL Studio to work properly because it uses stream counter to count the seconds.
- Ultimate Ticker.fsm
- (3.87 KiB) Downloaded 1114 times
Re: Ultimate Ticker (Unlimited Ticker)
Unlimited Ticker?
What you mean with this description?
Your ticker work at 100 ticks/s.
Hi Youlean
FYI, there is already a custom ticker (as well as ticker counter) included with FS. Although they may be in one of the "toolboxes" you have to download separately for whatever reason (which might be included in FL by default anyways; I honestly can't remember).
Your ticker doesn't seem to work accurately at high values (i.e. 44,100). I'm not sure but there may limitations to the rate of calculations in green. But to be fair, the stock Ruby custom ticker always kills itself when you try to run it too fast too.
Edit: sorry if it seemed stupid to say that it doesn't work at ridiculous values, but I guess it's just useful to understand the limits.
I noticed as well that your ticker counter didn't always seem to work after a while; not sure why. Also I tested and found your ticker works well at 4,410, so somewhere between that and 44,100 is your limit.
Oh, I found a much simpler custom ticker in green in my toolbox here.
- Custom Ticker.fsm
- (392 Bytes) Downloaded 1100 times
Unfortunately, this ticker is not usable as triggers are not constant.
