Random jumps in volume with 'randomOsc 8'/'Randy'?
Am I the only one experiencing this? Some presets when first striking a note are hugely loud and only return to normal volume after striking a few chords; then when a new preset is selected, same thing but not always :shock:
Could this have something to do with my machine being quite old (my usual one is in the shop)? This doesn't occur with it's predecessor, randomOsc 4 (?).
Given that, I did a version of randomOsc 4 with the same expanded features of what I called Randy +; Randy being Martin's chosen name for randomOsc 8.
My additions:
- Osc Pitch up or down 24 semitones.
- Second LFO using Martin's Multi LFO.
- Five-slot Modulation Buss.
- Wheel can be disconnected from Vibrato, for use with other destinations.
- Pitch Wheel generates three different, simultaneously available CVs - BiPolar, Up and Down.
- Dedicated Aftertouch sensitivity for Filter Cutoff.
- Two MIDI CC selectors that default to #16 and 17 for control by any MIDI joystick/XY pad that generates these messages (i.e.,Yamaha SY22, SY35 and TG33).
RandomOsc 4 + copy.jpg (46.5 KiB) Viewed 13607 times
RandomOsc4 +.fsm
(571.06 KiB) Downloaded 1017 times
I know Martin considers randomOsc 4 an 'unbaked cake', but for me Randy is right now unusable - if this is true for anyone else there's this to use till Martin addresses this (unless it only occurs on older computers, in which case, there's nothing to fix ;) )
With FS v3.0.8.1
Re: Random jumps in volume with 'randomOsc 8'/'Randy'?
k brown wrote:Some presets when first striking a note are hugely loud and only return to normal volume after striking a few chords; then when a new preset is selected, same thing but not always :shock:
Sorry, Kevin, there was a bug in the original post. Now fixed here: viewtopic.php?f=3&t=17621&p=54547#p54547
Any more bugs please report.
Oh - great!; I thought maybe I was nuts or my computer was busted.
I'll get GUI'd Randy all fixed up.
If you could identify where the 'fix' was, could I just replace that in my GUI version? - otherwise I'll have to re-assemble it all into the new schematic. Was it a single code module, or a 'structural'/'wiring' fix?
Thanks!
Still getting volume jumps in new version of Randy - while I await word from Martin about whether this might be specific to my machine (haven't heard from anyone else about whether they are experiencing the same thing), a few tweaks to RandomOsc 4 + (replaced in initial post).
- Pitch can can toggle from semitone-stepped to free-tune.
- A couple more options in the Mod Bank.
- A few presets of my own added.
- Fixed LFO 2 wave select not working.
I never heard from anyone as to whether they were getting these sporadic jumps up in volume, but Martin sent me a .dll he generated on his machine and it doesn't display this behavior, so it's clearly the case that my old PC was just creating faulty .dlls from this. It's a quite old machine so I'm not surprised, though I didn't know such a thing was possible; that a schematic 'plays' just fine but that the same computer generates a 'broken' vst from it. I get my newer computer back in a couple of days - hope it makes OK vst from this; I love RandomOsc 4 but the 8-note polyphony of Randy is definitely preferable.
I'll get the latest additions I made to RandomOsc 4 + applied to Randy and update that schematic.
