Pressure sensor at 10 ms
Posted: Tue Mar 08, 2011 9:42 pm
by geab
Any recommedation/experience with a pressure sensor that works together with FlowBoard DAQ
and Flowstone and can be sampled at 10 ms. Sensitivity should be at least 10 Pa or lower.
Thanks, Gernot
Re: Pressure sensor at 10 ms
Posted: Thu Mar 10, 2011 11:35 pm
by Cat5
You could just use the pressure sensor from Phidgets and connect it to the FlowBoard DAQ
You might need to use a potential divider (2 resistors)to get the correct voltage range for the FlowBoard (3.3V)
Heres the link :
http://www.phidgets.com/products.php?category=1&product_id=1115
Edit: Just noticed you wanted a lower pressure ;(
Posted: Mon Mar 14, 2011 1:28 pm
by geab
Thank you Cat5
I am not sure at would sample rate I could get data from the Phidget pressure sensor. If they can sample at down to 10 ms it would be great.
