Server in .exe issue *FIXED*
Posted: Sat Jan 15, 2011 4:37 pm
by Morph
Hi, i can not make the Network Server module work when exported to .exe, it just won't start and seems not even try to connect. It do work inside FS, also Network Client works in .exe but not the server or am i missing something?
Re: Server in .exe issue
Posted: Sun Jan 16, 2011 11:31 pm
by sal
hello,
same problem here.
Sometimes It doesn't start inside Flowstone too(try to push start several times and it will fail to start).
S.
Posted: Sun Jan 16, 2011 11:48 pm
by DSP
I have it working inside an EXE?
Posted: Mon Jan 17, 2011 12:39 pm
by Morph
DSP wrote:I have it working inside an EXE?
Is this test .exe working for you, DSP?
TEST ServerInside:
Posted: Mon Jan 17, 2011 4:19 pm
by sal
it doesn't work here.
There is something to be fixed on the server module.
S.
Posted: Wed Jan 19, 2011 3:10 pm
by TomC
Morph wrote:Hi, i can not make the Network Server module work when exported to .exe, it just won't start and seems not even try to connect. It do work inside FS, also Network Client works in .exe but not the server or am i missing something?
Did you exit FlowStone before starting the executable?
Because, if not, the server inside FS is still using the selected port numbers, thus rendering those ports unusable for anyone else, including FS executables.
Tom
Posted: Wed Jan 19, 2011 3:36 pm
by Morph
TomC wrote:Did you exit FlowStone before starting the executable?
Yes, had tried on other computers too, with no FS installed. No network activity.
Try my test .EXE. Is it working for you?
