How to remove empty items
Yuroun
Post by Yuroun »
I'm building a semi modular effect. The user can select an effect on every slot, but when an effect is chosen, then in the other effect slot must the effect removed. I'd build some logic, but I have empty places. How can I remove them?
See my schematic
SelectFX.fsm
(2.14 KiB) Downloaded 1152 times
briant1972
Re: How to remove empty items
Post by briant1972 »
I found some ruby code online. Seems to work. Try out the attached module.
SelectFX2.fsm
(2.37 KiB) Downloaded 1162 times
Jay
Post by Jay »
Hi Yuroun
I would do it like below, all one line and no extra bits required ;)
output @SourceString.gsub(@OldPattern,@NewPattern).each_line.reject{|x| x.strip == ""}.join
SelectFX remove empty.fsm
(2.24 KiB) Downloaded 1173 times
Best Regards
Yuroun
Post by Yuroun »
Thanks Guys. Both are elegant solutions. I prefer the version of Jay. He modified my Ruby code nicest ;)
Jay
Post by Jay »
Why thank you Yuroun!
glad it is of use for you m8 :)
Best regards
Yuroun
Post by Yuroun »
Jay wrote:Why thank you Yuroun!
Because it's a normal thing to do, If you get some help.
For me it is :D
nix
Post by nix »
It's a mannerism in English Yuroun 8D
Or was that a good for a pun?
hehe
Yuroun
Post by Yuroun »
nix wrote:It's a mannerism in English Yuroun 8D
hehe
Lol :lol:
Yuroun
Post by Yuroun »
Here's the version I had in mind. It's not working perfectly :roll:
SelectFX.fsm
(2.55 KiB) Downloaded 1178 times
Jay
Post by Jay »
yeh its just a saying Yuroun :D a bit like "well thank you very much"
I see what you mean about not working perfectly, it seems the last column does not always update properly, I will have a look at it and see what i can come up with :)
Best Regards
