obtain pointer to variable in assembler
I have found a way to obtain pointer to a variable in assembler code. Under normal circumstances, access to a local variable is restricted to the same ASM/code component and you can't pass it around. I have discovered a workaround that extracts the memory address (or a pointer) to any variable or array you choose.
This may come handy, expecially when you need to pass arrays between ASM components. It may also allow you to pass pointers to an array to a function from the ASM component - coupled with the machine code injection discovered by MyCo this could allow some pretty useful things. For example, one may execute FFT on various arrays, simply by having the FFT machine code in a string in ruby and calling it from ASM component.
- pointerToVariable.fsm
- (1.2 KiB) Downloaded 1379 times
Re: obtain pointer to variable in assembler
Hey that's interesting. I wonder: is there an advantage over the MemAddress prim? If your new method proves more stable, then I can see some applications like a fast wave reader, fast lookup tables etc. Wonder if this would also work in poly?
In the new version this will be very easy to do and it works in poly so you can make fast wave readers.
- mem.jpg (62.35 KiB) Viewed 18436 times
x64 assembler!!!!! :drolling:
francoisreme
I'll buy it ten times.
