Using OSC? Is it possible?
Posted: Thu Dec 06, 2012 9:27 pm
by qqwy
Hello there, everyone,
I am simply wondering, because I have a few controllers that send data through the Open Sound Control(OSC) protocol. Is there a way right now in FlowStone to catch and use these values?
Re: Using OSC? Is it possible?
Posted: Fri Dec 07, 2012 12:40 am
by Jay
most likely yes! the ruby inside flowstone should be able to do so!
here is a couple of implementations of osc stuff in ruby!
https://github.com/aberant/osc-rubyhttps://github.com/maca/ruby-osc ,
thats as much help i can give you m8 as i am clueless then it comes to ruby, but maybe some of the more learned ppl here might be able to point you in the right direction!
Our boffins from over at SM land are here as well and they are feverishly learning ruby as we speak
The Synthmaker Boffins yesterday.
- boffins.jpg (62.66 KiB) Viewed 26633 times
hope that helps
Jay
Posted: Fri Dec 07, 2012 8:10 am
by digitalwhitebyte
Jay wrote:most likely yes! the ruby inside flowstone should be able to do so!
Yes, but not now, with external libraries, the reason can be found in
this post.But the support is working on it.
except if the extensions are written in pure ruby, then you will have no problems,
extensions in pure ruby usually are suffixed with name-pr.
Posted: Fri Dec 07, 2012 4:25 pm
by rlr
Technically speaking OSC is nothing more than simple UDP datagrams. So in theory the built-in primitives "Network Server" and "Network Client" should do the job (not tested yet)
Posted: Tue Dec 11, 2012 10:25 pm
by qqwy
Thanks for your replies. I haven't tried the built-in network server and client yet, but I will shortly. I'll keep you updated
