tiffy
Post by tiffy »
TRIGGER SWITCH (RUBY)
Description inside module.
Trigger Switch (Ruby).fsm
(517 Bytes) Downloaded 1216 times
tiffy
Post by tiffy »
MOUSE CURSOR WITH TRANSPARENT COLOR FOCUS:
Mouse Cursor with Transparent Color Focus.fsm
(1.24 KiB) Downloaded 1235 times
Cool stuff, TIFFY :D
Thanks for posting !
tiffy
Post by tiffy »
1 Hz TICKER:
A simple general purpose Ticker/Flasher constructed with Primitives.
However, if you need accurate timing rather use a Ruby Ticker instead.
1 Hz Ticker.fsm
(2.65 KiB) Downloaded 1186 times
BobF
Post by BobF »
Hi Tiffy,
Great stuff, keep them coming. I am sure these will all be put to some good use in the near future.
Later then, BobF.....
tiffy
Post by tiffy »
GRAPHIC COUNT DOWN TIMER (Ruby):
The ticker & graphics make use of Ruby but other control circuitry make use of green.
Description inside schematic.
Note: The timer can only make use of "Full Seconds" and not "fractions of a Second" entered into the text Box. It will 'ignore' any fractions of a Second given to it. This is only a Display Example.
Graphic Count Down Timer (Ruby) v3.fsm
(35.92 KiB) Downloaded 1213 times
getting a RUBY error, undefine method, 'scheduleMethod'
tiffy
Post by tiffy »
RJHollins wrote:getting a RUBY error, undefine method, 'scheduleMethod'
Sad to hear, but with flowstone v3.0.7 it shows no error on my side. But I will have a look at the code, it is possible that there is some undefined method in there somewhere. Strange that the error does not show up in v3.0.7. which makes it difficult to detect if an error exist or not.
Does the error shows up in the "ticker" Ruby module (which is not my work) or in my "Graphic" Ruby module?
Thanks for your feedback.
scheduleMethod was introduced with 3.0.6, so you've done nothing wrong, Tiffy, just RJs Flowstone 3.0.4 is simply too old.
I propose to clarify which version of Flowstone is needed as a minimum to use Ruby-modules. One could consult the changes list of the versions, maybe.
Thanks for checking TIFFY. It was in your module.
It would be difficult to know what version everyone is using ... yeah, I'm still with 3.04. Most times this has not be issue ... but every once in a while. :roll:
