Page 4 of 12
Re: FlowStone 3.0.9 Beta1
Posted: Tue Dec 08, 2015 9:19 pm
by Nubeat7
great thx :)
Posted: Wed Dec 09, 2015 12:00 am
by Walter Sommerfeld
Ooops - overlooked this bug:
One grid is missing vertical on the right Border and horiz. at the bottom in Focus Mode and on the right in EXE's
Posted: Wed Dec 09, 2015 12:07 am
by MyCo
hehehe, funny thing... we noticed it too, and are already investigating
Posted: Wed Dec 09, 2015 12:16 am
dunno if it's related with this beta:
after a crash (could not reproduce it now) a left over recovery file let all double clicked .FSM again crashes on load...
Loaded via FS all was fine... after deleting buggy *(recovered)pid=nnn.fsm => all normal again :)
Posted: Wed Dec 09, 2015 8:13 am
MyCo wrote:Another option (which is actually easier to handle) would be like this:
1. open Regedit and export the key HKEY_CURRENT_USER\Software\DSPRobotics\FlowStone to some file
2. install 3.0.9 to a different program directory (so you don't overwrite the old version)
3. open Regedit and export the key HKEY_CURRENT_USER\Software\DSPRobotics\FlowStone to some other file
To switch versions you just double click on the corresponding regedit export file.
I chose this option, however after switching to 3.0.9 and back to 3.0.8 I get this:
Please help!
I really appreciate the beta and generally support the approach. However, next time please provide a proven recipe for use in parallel with last stable FS release. ;) Thanks again! :D
Posted: Wed Dec 09, 2015 12:33 pm
by MyCo
well, then you probably have the wrong regedit export clicked before switching. It's not that I just made this up... I use that workaround myself :mrgreen:
Important part is actually this key:
"HKEY_LOCAL_MACHINE\Software\DSPRobotics\FlowStone\Install Folder"
You might need the right windows user permissions to update the registry, maybe that's the problem. Just check the key if it's pointing to the right directory / check the FS help dialog if you're actually running the right version.
Posted: Wed Dec 09, 2015 12:39 pm
Walter Sommerfeld wrote:dunno if it's related with this beta:
I get that sometimes in 3.08.1
Posted: Wed Dec 09, 2015 10:51 pm
MyCo wrote:well, then you probably have the wrong regedit export clicked before switching. It's not that I just made this up... I use that workaround myself :mrgreen:
Thanks, MyCo. It does not work for me, though. :( There is no FlowStone install folder entry entry in my registry to begin with, neither for FS 3.0.8 nor for FS 3.0.9 (which, of course, are installed in separate directories). Somehow FS always grabs the 3.0.9 Ruby library regardless of which FS version I use (the version used manifests itself, among other things. by the presence or absece of code line numbers). I can't wait to ckeck out all the cool new features, however i need to have FS 3.0.8 available for current projects. :x
Posted: Wed Dec 09, 2015 11:05 pm
by MyCo
Maybe you'll have to use this key:
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\DSPRobotics\FlowStone
Posted: Thu Dec 10, 2015 12:08 am
Bingo! It's there! And there is one Install Folder specified, which is the FS 3.0.8 folder. That explains it. So how do I add the FS 3.0.9 Install folder? I did choose a different folder during FS 3.0.9 installation. The 3.0.9 folder has been created, and Flowstone.exe and all the other files are there. Apparently the installer did not create a proper entry in my registry. :?: :?
