MVerb 7 - yet another reverb?
lalalandsynth
Post by lalalandsynth »
On Off animation.
Mverb On off.gif (37.98 KiB) Viewed 17839 times
lalalandsynth
Maybe a custom dropdwn. Complicated but doable
Mverb 7 Custom Drpdwn.png (157.45 KiB) Viewed 17837 times
lalalandsynth
Wonder if the Freeze should latch or be momentary
lalalandsynth
Minor refinements and on off states for knobs switches.
proper state of orange strip on RT60 knob.
Mverb 7 Refinements.png (157.71 KiB) Viewed 17834 times
lalalandsynth wrote:Wonder if the Freeze should latch or be momentary
Right-click latch, left-click momentary?
lalalandsynth
Yes, that would make sense, waiting for the go ahead from Martin before I start doing the animations . ;)
lalalandsynth
oh crap....
I am working on the 64 bit Alpha version ... Well, everything works and its very stable .
So this version will be 64 bit.
lalalandsynth
Getting somewhere , animation the circular orange thingies is a problem , will figure something out.
Mverb Switches.gif (134.67 KiB) Viewed 17827 times
lalalandsynth wrote:First Draft with one slider for wet-dry , added volume and a reverse function , mostly because i need to fill space :D
Maybe the “Reverse” button could determine whether the live input to the reverb is killed or not, when Freeze is ON? It would be nice to have both options I think.
lalalandsynth
yes, will try that .
Managed to animate the circular knob ,was quite tricky masking work in After effects, well, for a novice like me anyways.
Circular animation.gif (301.08 KiB) Viewed 17825 times
