Synthmaker bundle
Decided to do an alternate version of TriGoom for those who find the two-sliders-with-knob-between oscillators confusing, uninspiring, obsequious or clairvoyant.
This version's oscillators have a single waveform control knob, similar to Micromoog/Multimoog and Voyager - produces Tri thru Saw to Pulse. In addition an FM control that phase modulates each oscillator's two internal triangle waves. Also a control that either boosts or weakens the fundamental (inspired by the JP-8000, but in this case it affects all the waveforms).
TriGoom_osc2 :
DrewDale
Post by DrewDale »
No Soup R Saw,
LFO-1 not functioning as I would expect an LFO to work. ?
Set value (rate / fade) play a few notes, no effect, play a few notes and then change either Rate or Fade and you will hear the LFO. release notes and play again, no effect.
EDIT.
Scratch that, I had epic failed to change the LFO depth knobs :roll: works fine. :oops:
DrewDale
Post by DrewDale »
A question.
Will some of the synths that had parameters named by knob twiddler be resized to the gui's that you originally created ? most of his had very large UI's.
Thanks.
No - he made those with Flowstone, so I can't open them. You'll have to get KT to do that. I was hoping when Spogg made that free last version of Synthmaker available that folks would use that to make changes so I wouldn't be 'locked out'.
Something inspired by the Quasimidi Polymorph. It's in no way intended as an emulation - I just thought the idea of a synth with four sequencers, one dedicated to pitch and the others freely assignable was interesting enough to do something similar even with the simple step LFOs. It's filter was interesting as well - somewhat similar to the CS-80, but with the LP switchable between 2-pole and 4-pole, the HP and LP can be either series or parallel, and each have a dedicated EG.
I simplified the oscillators to all three being similar to Polymorph's Osc 1; standard waveforms. A couple of functions the PM didn't have - Osc 2 can FM Osc 3, and Oscs 2 and 3 can be Ring Modulated.
PolyStep:
To those who already downloaded PolyStep, re-download it - found and fixed a couple of errors.
megatherium
Post by megatherium »
Hello,
I've made 20 presets for Kevin's Rolend SH-12 VST.It's an FXB file.The rest of the bank is an initialise preset.Works fine in live 9 lite and cantabile 2 lite.Download here;
gabbroliticaudio.weebly.com
DrewDale
Post by DrewDale »
megatherium wrote:Hello,
Thanks for the share, nice patches here :D
Happy New Year!
For those whose hosts can't save presets as .fxb, all plugs in the 'Named Params' folder now have a Preset Manager added.
The ones just done are:
80-vox
Cassini
Chorg 770DV
Insoniq EZQ-FM
Kroma Duette
M
minimodular
Multipoly
OatsFM
Polly
Rolend Block-8
Rolend Block-8_cables
Rolend JP-680
Rolend SH-57
Rolend SH-75
Rolend System 101M
Rolend System 101M_4eg
Synthakon
Synthegrated 12A
Synthegrated 15A
Synthegrated 80
SystemOne D
toneBoardz
tonus Pro Colorist
Zoomchak
Zoomchak Pro
- Cheers
Finally got 'round to doing one from the original Bundle that never got did.
Insoniq EZQ-1:
Insoniq EZQ-1 copy.jpg (90.87 KiB) Viewed 30793 times
Like EZQ-FM, but with wavetable oscs in place of 2-op FM.
