Re: save wav recorder
Posted: Mon Aug 03, 2020 1:51 pm
Spogg wrote:The only DAW I know that can’t deal with an effect with midi input is FL Studio. Reaper can handle it with no problems. Adam once told me it was actually possible, but not how, and I don’t use FL myself.
I am using Reaper, I have to continue researching on how to connect the midi input of my vST as effect.
Spogg wrote:I’m glad you’ll find my recorder of some use. Its usage was intended to capture a sound or short performance clip from a synth. To record longer performances you could consider what I do for my videos. I take the audio out from my USB audio interface (running ASIO) and put it into the motherboard’s line in and record from that. Then you can use Audacity for example to record as long as you want. I find that the motherboard sound is perfectly acceptable, but I’m no audiophile!
I`m glad too, thank you! Despite my need for long time recording, your recorder may be useful to download audio loops while playing a synth. That`s another old idea to incorporate on my project. Regards to your way to record, It is useful for a fixed equipment at studio or home. I used that way time ago.
I want to make live performances with FS synths. That implies transport my set, and therefore, ensembling - disasembling often. And it is a risk when I has a lot of software and hardware interconnections and settings that may change unexpectly in each new assembling. That`s my reason to minimize my software dependance, to make the remaining software is more easy to maintain in gear. At this view point, I started to see as a possibility to record from another PC or notebook.
