New PWM
Re: New PWM
I noticed this produces pretty severe distortion/aliasing on higher notes - any way to smooth that out?
Does this maybe only work best in blue?
Re: New PWM
Hi Kevin,
Try this one!
Good luck, BobF.....
Re: New PWM
Thanks for that - however I would describe the results as a mild improvement at the expense of noticeably duller sound.
Re: New PWM
Hi again Kevin,
Unfortunately aliasing is common in many distortion and wave shaping devices. If you missed this post read it over for possibly a little more help.
Reducing aliasing of waveshaping using convolution.
Try the conv tanh.fsm and see if it helps any better than the anti-aliasing filter I added.
And last, you could also remove some of the 1 pole low pass filters from the 36db anti-aliasing filter, they are each 6db. This could add a LITTLE punch back in.
Good luck and please let me know how you make out.
Take care, BobF.....
Re: New PWM
A 'convoluted' answer!
- I'll give it a try.
Re: New PWM
Bob, unfortunately the 36 dB filter is just a simple filter its not anti-aliasing at all. You cannot remove aliasing by simply filtering the signal with a low pass filter, its not how it works.
Re: New PWM
A simple antialiasing technique consists in synthesizing the time integrated waveform and then numetically differentiate it. Example: a square wave is obtained by differentiating a triangle wave. The method is called DPW (differentiated polynomial waveform).
Re: New PWM
My bad on the antialiasing filter, just found it in another schematic and well used it. Sorry!!!
Later then BobF.....
Re: New PWM
Hello all,
Had this laying around, so just thought I would add it for completeness.
Later then, BobF.....
@ Adam, it's fixed, very sorry!
