Rubygems
Re: Rubygems
Wrapping up into a FlowStone Project:
As you say works without the buffer? Maybe it's a Ruby thing as you don't have to define the size of the variable?
require "Win32API"
def event i,v
getForegroundWindow = Win32API.new('user32', 'GetForegroundWindow', 'V', 'L')
window_handle = getForegroundWindow.Call()
getWindowText = Win32API.new('user32', 'GetWindowText', 'LP', 'I')
title_buffer = ' ' * 512
getWindowText.Call(window_handle, title_buffer)
output 0,title_buffer
endAs you say works without the buffer? Maybe it's a Ruby thing as you don't have to define the size of the variable?
- Ruby Get Window Title.fsm
- Show the Title of a Selected Window
- (466 Bytes) Downloaded 1277 times
Re: Rubygems
thank you,
i did already try do change the PATH and my mistake was about my ruby version compiled with minigw, with the mswin version i can use some gems and i'm having problems with some other gems(the ones i would use) such as the sqlite3 and the mysql ones.
For example trying to require sqlite3 from irb it works, but inside flowstone ruby module it doesn't.
- sqlite3fail.jpg (34.5 KiB) Viewed 10187 times
- sqlite3.jpg (17.63 KiB) Viewed 10187 times
