Pad selectors(or "radio" selectors)
Re: Pad selectors(or "radio" selectors)
well, the preview in the properties is a great feature, i always forget about this.. :)
djbrynte
Post by djbrynte »
great work!
billv
Post by billv »
Note Small Bug :
(.to_f) needs to be removed twice in code..
output 'altVal', @altValue[@sel].to_f
the conversion to float in the alt_value output prevents string/int output ...
yes, thats a question of what you need as alternative outputs, i took .to_f because i thought that this would be a common use for it, but sure if you need string you don't need to add anything and you can get rid of the ".to_f" also if you need int but if you need floats you need to add ".to_f" maybe you could just comment it, so it just nneds to be uncommented when floats are needed...
it also depends if you are using the ruby value, then it will always be sent as string if you don't convert it, while if you use green outs, the outs would convert it, then you dont need to add anything..
alternative to make it userproof you could make a selector in the properties and output with cases...
just like this..
Pad Selectors_nubeat2.fsm
(84.4 KiB) Downloaded 1073 times
billv
Post by billv »
Nubeat7 wrote:make it userproof you could make a selector in the properties and output with cases
yeh,much more practical...Nice.. :)
billv
Post by billv »
taking nubeat7's mod a little further, and a bit closer to Trog's example that
inspired the initial idea, here's one with rows and columns..
Pad Selectors_BV_RowsandColums.fsm
(99.57 KiB) Downloaded 1087 times
fantastic billv !
8-)
billv
Post by billv »
Thanks RJ.
I found also by changing the order of just two lines of code, instead of incrementing
on the Y axis, can do the X axis as well. The whole module just "flips" around... :lol: :D
So I re-uploaded it...you can set the new "Direction" parameter in properties.
Cleaned up the code a bit....
Walter Sommerfeld
Post by Walter Sommerfeld »
Hi billv,
awesome part this RowsandColums.fsm...!
Can u change it 4 me so i can (de-)select multiple pads while dragging ?
cheers,
Walter
