ReFlow - Send back data in one link
chackl
Post by chackl »
Hello!
I did a new example with some help :D
It sends data back through one link - so you can reverse for example wirelesslinks.
Regards
EDIT:
Corrected Class Error
reverser.fsm
(1.35 KiB) Downloaded 1538 times
Re: ReFlow - Send back data in one link
get a ruby error message: in method 'load state': undefined class/module revflow
chackl
Post by chackl »
Well i do not see why.... i'll take a look
chackl
Post by chackl »
Well i saw it now - i got a class error - but i do not realy understand it jet...
Why does flowstone give me a wrong class if i:
Delete an old class and do not use it anymore - LoadState error if i have NO loadstate inside
I could only correct it getting al modules into a now schematic....
Why?
Regards
I had seen the same error message ...
I went in and reset the RUBY modules [Off, then ON]. This 'cleared' the red highlight error. but things were still not working.
I then reconnected the inputs feeding the module ... and then it worked.
I don't know the reason why, but that was my troubleshot and fix. I just loaded up the re-saved schematic and all seems to be working.
user guide says:
"The Ruby component saves its state. If you save a schematic with a Ruby component in it then when
you load it back the @ins and @outs arrays are restored to exactly how they were before. This
ensures that the component maintains its state at all times."
so i think it has something to dowith the persistence of the ruby component
chackl
Post by chackl »
Well in the aktual one i have corrected the triggers and the error does not come up anymore - the updated is in the first post ;)
Regards
confirm no error :)
