RBJ Filters - Audio Biquad - RubyMaths
steph_tsf
Post by steph_tsf »
http://www.musicdsp.org/files/Audio-EQ-Cookbook.txt
Here is a Flowstone implementation and generalization of the RBJ Filters.
IIR BiQuad.fsm
(28.92 KiB) Downloaded 1452 times
IIR BiQuad (RBJ).fsm
(216.02 KiB) Downloaded 1455 times
IIR BiQuad (RBJ and knobs).fsm
(225.93 KiB) Downloaded 1473 times
MyCo
Re: RBJ Filters - Audio Biquad - RubyMaths
Post by MyCo »
Just in case you haven't seen it already:
viewtopic.php?f=3&t=1234
steph_tsf
Post by steph_tsf »
MyCo wrote:Just in case you haven't seen it already:
That's great. Thanks.
For equalizing speaker drivers, like for battling against cone breakup in the high frequencies, most of the time you need a combination of LPF, BPF and HPF, for implementing a kind of refined notch.
In the deep bass end, most of the time a Linkwitz Transform (BassBoost/Equalizer) will exhibits the same need.
A simple shelving tone control (Bass/Treble) also requires that you combine the LPF, BPF and HPF outputs of a BiQuad.
