Latest update for Martin's 'Randy' synth
Re: Latest update for Martin's 'Randy' synth
And here's Randy + with the Noise EG :
Randy +_k.fsm
(607.03 KiB) Downloaded 1062 times
Randy +_k copy.jpg (172.44 KiB) Viewed 20335 times
Julian Ray
Post by Julian Ray »
Thanks a lot, Kevin!
I'm going to make some nice presets now.
Here's Randy + with the Noise EG and a dedicated Modulation Envelope:
Randy +_k3.fsm
(639.48 KiB) Downloaded 1028 times
Randy +_k2 copy.jpg (179 KiB) Viewed 20122 times
And all my presets included and working, too - very nice! :D
Julian Ray
Great !
Julian Ray
As Noise has it's own filter, it might be useful sometimes for noise to bypass the main filter.
Like a switch in the Noise section.
What do you think guys?
Yeah, I'd like to hear Martin's thoughts on the Noise routing. It goes through hell on it's way to the output :shock: ;) - first it's own comb filter, then the main Filter and finally the Spectral Tilt filter, which the way Martin did the original GUI layout would lead one to think is only affecting the oscillator/s.
Julian Ray
Of course!
By the way... I've noticed that Tilt knob has max signal level around 0.5 and the level greatly drops close to 0 or 1.
Just theoretically, is it possible to compensate, so that level will keep the same through the whole Tilt knob rotation diapason?
There are some good sounds out there :D
I had other thoughts about this, such as providing the option of bypassing the EG (as in the original), shaping by the VCA EG instead, re-routing the Noise through the Comb Filter only, the main Filter only, bypassing the Spectral Tilt, etc., but any further tinkering would have to be done by Martin. 8-)
Julian Ray
trogluddite wrote:
k brown wrote:but not being very 'norm' myself
If you do see any "normal" people showing up on the forums, you should immediately report this to a moderator - we can't be having that kind of behaviour going on around here! :lol:
:lol: 10/10! I really wish there will be LIKE button here, on forum :D
