How can I add a Pitch Envelope in Roting Matrix
- djcrazyvdj
Is there any way to add pitch envelope in Routing matrix which will be controlled by ADSR envelope? Just like sylenth we add Pitch and control the ADSR envelope to add an extra edge/punch. This is also helpful to make Kick.But how can I make it inside Flowstone? Please help me.
Cheers!!
DJ Crazy
Cheers!!
DJ Crazy
DJ Crazy
Re: How can I add a Pitch Envelope in Roting Matrix
You put a stream multiply in series with the 0-1 frequency for the oscillator.
On the other input to the multiply you put a float value of 1.
Then you can add (or subtract) to this float value with the ADSR output. So when the output level of the ADSR is zero the pitch is unchanged. As you bring up the ADSR level it will increase or decrease the pitch from the envelope. This is then independent of the actual pitch because x2 will be plus one octave.
Hope that helps.
Hope that helps.
- djcrazyvdj
Thank you Spogg, but unfortunately this is not working. May be I am doing something wrong. Here I have attached my Schematic. Would you mind to check and correct me?
Thanking you,
DJ Crazy
Thanking you,
DJ Crazy
- Pitch Env from ADSR.fsm
- (158.24 KiB) Downloaded 1547 times
DJ Crazy
Here you go my friend.
I've put a comment box in with what I did.
- Pitch Env from ADSR spogged.fsm
- (347.7 KiB) Downloaded 1523 times
- djcrazyvdj
Superb my friend. Now this is working like a charm. Thank you so much.
Spogg Rockzzzzz.
Yo
Spogg Rockzzzzz.
Yo
DJ Crazy
DJ are you trying to create a VST synth? mybe i can help send you a synth with everything routing matrix and more? everything u need is added. and pls then dont use my synth. Its just for example ofc u can use the modules. But do not just copy the synth. If you like ofc?
