Sub-Selecetion Designer
chackl
Post by chackl »
I made a Sub-Select designer
Well i'm using Synthmaker/Flowstone since some time .... and i just found out that this is possible :o
So i just made a little designer example for it ;)
Regards
sel_cat_designer.fsm
(2.04 KiB) Downloaded 1553 times
tester
Re: Sub-Selecetion Designer
Post by tester »
Thanks, I was just trying to recall from the past - how it was made, because need to reorganize some menus into subsections.
chackl
Post by chackl »
tester wrote:Thanks, I was just trying to recall from the past - how it was made, because need to reorganize some menus into subsections.
It is done like this ;)
Cat 1,>>,List 1,List 2,<<,Cat 2,List 1,List2,>>,Normal List1,Normal List2
So:
>> Go into Subselection
<< Leave Subselection
Regards
tester
Post by tester »
I know, I know, it was just about year ago, when I last time saw it.
If you don't use things, it's difficult to remember them. ;-)
philton
Post by philton »
you can also save some space in dropdown menus when using "interactive" lists.
here is a simple example. if MIDI Learn is off, the menu will only show the option"activate learn" .
when learn mode is active, the menu will only show "deactivate Learn".
with this method you can easily manage submenus with more than 1 possible item "checked".
example of a interactive dropdown philter5.rar
(16.24 KiB) Downloaded 1643 times
