Hysteresis Gate
Hysteresis Gate
This example shows how to use the Hysteresis Gate module.
In this case the slider varies the input signal and an upper and lower threshold are set. As you move the slider up the LED will not come ON until the upper threshold is hit. Once this case is true the LED will not go OFF until the lower threshold is hit.
Thus making a dead band in the middle to eliminate slowly varying signal such as Thermocouples etc.
- Hysteresis Gate.fsm
- Hysteresis Gate
- (17.13 KiB) Downloaded 2697 times
