Cubase 8.5 Plugin Error
- remarkable
Re: Cubase 8.5 Plugin Error
Nubeat7 wrote:with all the open ends and inputs its no wonder that it crashes, there is no signalflow from input to output, the input gets just lost in a dead end after the input amp, this would also fit with your crash info that vstbridge lost connection....
Actually, please don't think that there are open ends outside of the FX unit. Because I linked the conections when exporting as vst unit. Could you focus on the the FX module? Is there a strange thing?
sorry, but how should i test anything when its not even connected right? also all the packings doesn't make any sense to me because you connect mono4 with mono connections and its a big chaos at all...
like i said before clean up, make a clean working schematic where at least all the audiosignals are connected, the guis are minimized and the signalflow is clear to see, otherwise it is too much work for me just to have an overview whats going on and then start to search for bugs....
if it started with the fx section reduce them so long till it is working again...
