triggerdelay in samples - Ruby?
hallo,
i would need a triggerdelay where you can choose the time in samples, tried out some things but couldnt get it, someone of you has an idea where to start or how to do it, maybe modifying the ruby ticker ?
Re: triggerdelay in samples - Ruby?
Hi Nubeat,
This should do what you want...
Samples Delay.fsm
(1.11 KiB) Downloaded 1747 times
...couple of things to watch out for, depending how accurate you need it.
- Must be an ASIO/DS component running for accuracy; 100Hz clock is used when no audio running.
- Sending the output trigger through lots of green components will also make the timing a bit more 'slack'; keeping it all in Ruby/MIDI is more accurate.
nix
Post by nix »
ooh!
Haven't tested, but thanks a bundle trog.
I bet I use this somewhere.
Much appreciated!
thanks, trog exactly what i was searching for! and a little step to understand ruby a little bit better :)
