Custom DSP Code 2 (comunity project)
Re: Custom DSP Code 2 (comunity project)
Well I finally got to test this for real and unfortunatley I just get a Ruby error which I have no chance to understand:
I copied and pasted the DSP code from the AHD envelope generator into the string input box but couldn't clear the Ruby error. I did try to put the semicolons after the hop codeblock end bracket but to no avail.
I determined that any code after the hop end bracket would cause the error and the whole hop section wasn't being compiled.
What am I doing wrong?
AHD code produces Ruby error.fsm
(572.54 KiB) Downloaded 962 times
Post by KG_is_back »
Unfortunately this compiler currently doesn't work. It's a rather old project which was rather above my skill, especially as far as debugging goes. The problem is due to ruby interpreter - it sometimes bugs out when it tries to interpret multiline strings. I would have implemented it completely differently today. I was considering making a new version from scratch once FS 3.0.9 is released, since it upgrades quite a lot of features.
Thanks KG, at least it's not down to my error!
I'm using 3.08.1 BTW. I don't know if that makes a difference.
