FlowStone 3.0.9 Beta2
djbrynte
Re: FlowStone 3.0.9 Beta2
Post by djbrynte »
are the wave read bugg fixed? the one when you use FM?
Also flowstone crashes when i open a project.
any news about when the final version will be available, i'm sitting on needles to finally update from 3.06 to take profit from all the new stuff since then :)
Rocko
Post by Rocko »
This seems to me as a bug as well.
Cascading two 'code' modules and connecting the output to 'ASIO out' provides wrong result.
It seems that one value overwrites the other.
Please see attached file. I had marked 'wrong' and 'right' values acordingly.
This is what I see on my screen:
http://pasteboard.co/e4RMgco5X.jpg
Why is 'wrong' set to 0.5, while it should be 1 (only when connected to ASIOoutput) ?
Bug_1.fsm
(1.11 KiB) Downloaded 2022 times
the Mono to Frame prim seems to have an issue. I am experiencing random crashes with the schematic on page 223 of the manual (see below) when I switch off stream processing.
It happens with any of Direct Sound, ASIO4ALL or the ASIO driver of my adapter.
It happens with FS 3.0.8.1, FS 3.0.9 Beta, and FS 3.0.9 Beta2.
Anything you can do about it? Many thanks.
MyCo
Post by MyCo »
@Rocko: You are writing to an input variable
@Martin: I'll have a look... but I guess it's one of those problems that depend on the system (As I would have noticed that before)
Thanks MyCo.
My system is Win 7 Home Premium SP1, 64 Bit, Athlon II X4 640 if that is of any help at all.
MyCo
Post by MyCo »
I can reproduce the problem... it looks like a deadlock of something, quite hard to figure out what's actually causing this
Duckett
Post by Duckett »
New user here (Win 7 x64), just checking in to say that 3.0.9 Beta2 crashes more often than not... it doesn't seem to be any particular action that crashes it, but I can get an average of 5 min. before it dies.
lalalandsynth
Post by lalalandsynth »
Always crashes for me when i close properties for a knob.
Lots of crashes when messing with knobs.
what happened with the beta?
is it still in development, or did the devs quit?
