FlowStone 3.0.9 Beta2
gvalletto
Re: FlowStone 3.0.9 Beta2
Post by gvalletto »
Hi all.
I have crashes when loading bitmaps in recently pasted modules. Pleas see the attached scheme, it has an explanation.
crash in pasted module.fsm
(12.43 KiB) Downloaded 2269 times
Tronic
Post by Tronic »
Estimated date of official realease? :roll:
gvalletto
Post by gvalletto »
between February and March 2016 (is the last version released)
Tronic
Post by Tronic »
I ask not for Beta version, but 3.0.9 Release version.
gvalletto
Post by gvalletto »
Excuse me, I do not understand your question. (My English is poor ...) I have used all versions of Flowstone, but the problem occurs in the latest beta version, which is 3.0.9 Beta 2. Previously I used the version 3.0.9 Beta 1, and before 3.0.8.1 Skylark, but all worked well.
Meanwhile, I observed that the problem is not with bitmaps. The crash occurs with several other modules. The sequence is always the same:
1- copy the module
2- paste it.
3- attempt to modify it or go inside the properties panel
4- FS crash.
gvalletto
Post by gvalletto »
sorry, I don´t know how to find the exact date of release
gvalletto
Post by gvalletto »
Hi Tronic, is this the date that you asked? (see attached bitmap)
FS date.PNG (5.65 KiB) Viewed 53396 times
adamszabo
Post by adamszabo »
He is asking for the official version and not beta. But no one knows that when it will happen.
gvalletto
Post by gvalletto »
Hi Adam, nice to meet you. I admire your JP6K VSTi. Nice, friendly and powerful!
I sent email to Flowstone support for the crash but I have no response.
Thanks by your post.
Regards,
Gustavo Valletto
Solcito Musica
Hey MyCo,
you didn't react here for a while. If you don't want anymore reports regarding 3.0.9 beta 2, please say so. Until then I take the chance to ask if it would be possible to add a mouseOver parameter to Ruby (probably to the View class), that behaves the same way as the prim (mouse is over = true, mouse is not over = false)?
It wouldn't need a way to enter an area, just the whole view. I ask, because the mouseOver Prim is currently the only way to tell if the mouse leaves a view. Often times you want to clean up the view when the mouse leaves the view, if prior you did drawings dependent on mouseMove, for example.
