New project idea
New project idea
Gonna try to approximate this very cool EQ used by Decca in the Sofiensaal from Gotterdammerung on:
Decca EQ copy.jpg (158.19 KiB) Viewed 25280 times
Screen Shot 2022-03-21 at 10.19.28 AM copy.png (102.74 KiB) Viewed 25280 times
Anybody have a cool rotating text module I can use on the knobs?
Pretty exciting to think I can use this vintage Decca EQ concept on my own Classical recordings!
DaveyBoy
Re: New project idea
Post by DaveyBoy »
Here we are K:
Curved Text 2.fsm
(26.7 KiB) Downloaded 908 times
Credit has to go to ChrisHooker for the original upload.
http://www.dsprobotics.com/support/viewtopic.php?f=2&t=17246&hilit=rotating&start=20
If you look on page 3 of the topic there are some related goodies from Trogg & Nubeat.
Have fun :D
No, not curved text, but text on a knob that rotates with the knob (see pic).
k brown wrote:No, not curved text, but text on a knob that rotates with the knob (see pic).
Text rotation is not part of GDI+ and therefore not available in Flowstone. You could painfully draw the text into a bitmap and rotate that one with the knob, but that would be way to much work for this small effect.
Instead build a graphic containg the text for rotation and rotate it in Knobman.
kortezzzz
Post by kortezzzz »
Does something like that helps?
rotate text with a knob 3.06.fsm
Made with v3.06
(6.16 KiB) Downloaded 858 times
I'll give it a shot, thanks.
kortezzzz wrote:Does something like that helps?
That's a good example of the bitmap rotation I talked about. Rotation is more expensive CPU wise than just drawing a bitmap, but this shows very well, how it's done!
It was on my To do list but you beat me to it! It’s what I had in mind.
Well done that man!
kortezzzz
Post by kortezzzz »
tulamide wrote:That's a good example of the bitmap rotation I talked about. Rotation is more expensive CPU wise than just drawing a bitmap, but this shows very well, how it's done!
Thanks.
It's also a little heavy with triggers expenses. But as long as the plugin is simple and lightwieght, it shouldn't be a problem.
Spogg wrote:It was on my To do list but you beat me to it! It’s what I had in mind. Well done that man!
Unfair match because I've already needed something like that before, so it was lying in my toolbox.. ;)
I'll do two versions of the EQ, with and without the rotating text; will be interesting to see what the diff will be in CPU load.
