Sourcing this Synth and oscillators
Hello,
I am a sourcing this synthesizer as i have currently i have found little time or interest in continue to develop it.
the oscillator is the result of a couple of years of experiments and inside the file you will encounter some of modules that represent the diferent stages of its development.
the first little box under the synth is the very first prototype, it consists of a main window with 3 clicable wave forms
that wil open individual windows for further shaping and morph.
the same happens in the blue window module, that is an evolution of the first, yet with some buggy and clucky response... with some patient, you will manage to click in the waves spheres and open the interior of each oscillator.
the last one, is a more simplified version which lead for the main structure of the synth it self.
The main synth uses very simple modules and its fairly easy to understand its schematics.
Regards
Regards
- Source 1.fsm
- (3.72 MiB) Downloaded 1102 times
Re: Sourcing this Synth and oscillators
Thanks for sharing your work Ricciardo!
I’ve had a quick look at it and I must say it’s a shame that you’ve abandoned the project because it looks good and has potentially a wide range of sounds. The schematic is very neat too.
Maybe someone here will pick up on it…
- StereoSpace
Either the Unison is overloading the output or I just broke it somehow after turning on the Unison. Even after resetting the audio is not making any sound anymore. It makes only one click.
Did anybody find a solution yet ? I think I'm having a similar problem after changing some settings. I can't tell if it's a unison problem or not.
