Tempo Bug With Reason 10
When the first instance of the plugin is loaded in Reason 10 the tempo seems to be automatically adjusted/detected/set properly but only for the first instance. The second instance of the same plugins gets initialized with a much higher tempo and everything gets out of sync. Any ideas how to solve it or what is causing it ?
