Cable sys. builded from scratch
hardwarehost
Post by hardwarehost »
Hi everyone! This is cable system builded from scratch without lookong at others work! Its the simpliest i ever saw. Its full of bugs, but the functionality is there. I dont have the time to check all the tickers issues.
Snaping: click on the first bmp and drag the line near second until the color change and push - you see: it fits automaticly : D
Deleting: doubleclick on any bmp
Dont connect: If the color dont change, simply push - its restarted
Connection: if you see the color then the value changes 0 to1 use that in matrix
Active area: go on bitmap with mouse - you see only from the the jack space you set anything
mod mat udr kab sna 2.2101.fsm
https://gofile.io/d/2FpI96
hardwarehost
Re: Cable sys. builded from scratch
This is how far it gets now:
- 6 sources, 6 destinations
- gui moveble order
- multi dest. input, 5to1 possible
- second modulations via order change
Snap 2020-12-02 at 10.49.15.png (274.66 KiB) Viewed 10538 times
Snap 2020-12-02 at 10.52.07.png (263.53 KiB) Viewed 10538 times
I need to optimise the schematic, I am not the guy that cares about light-up of it, i only hurry-hurry on results, never wrote notes for future, or make it universal for easy use 1st time - next time. So if someone could do that - its really important here because its gonna be CPU expensive anyway, and i dont wanna make simple modules :cry: then. Any idea to this is welcome.
6x6 here:
ARC3 2xS multi t t f all fits 6x ok.fsm
(1.91 MiB) Downloaded 1014 times
The inp. /out. is on same place as you see on RETRO and TESTED its only about to add bmp there
