Somewhat different peaking EQ filter
I had a little DSP excercise which kept me busy for two weeks or so. The objective was to create a bell-shaped filter which is more concentrated around the center frequency than the common RBJ biquad, but at the same time has a flat top. This is what I came up with.
biquad EQ.png (18.44 KiB) Viewed 18567 times
4th order EQ.png (17.49 KiB) Viewed 18567 times
The schematic includes a 5-band demo equaliser (stereo, optimized). Feel free to use, integrate into your projects and modify if you like.
EQ 4th order.fsm
(39.18 KiB) Downloaded 1360 times
adamszabo
Re: Somewhat different peaking EQ filter
Post by adamszabo »
Very interesting, thanks!
Very nice as always Martin!
It must be great to be able to think of a filter shape and behaviour and then be able to make it.
Thank you so much for sharing this and all your other amazing work.
