Poly Slicer V1.0 Alpha
Re: Poly Slicer V1.0 Alpha
It's strange somehow. This as well as all plugins done with Flowstones crash with exactly the same error report when I try to load samples. Since none of my tools, DAWs or non-flowstone.plugins have any issues, I always thought it's a bug with Flowstone. But to be sure about it, I made a drum loop, saved three times as 16 bit int, 24 bit int and 32 bit float.
Please have a look. If it doesn't work, you might find out why. And if it does work, I wonder why it doesn't on my system?
loops.rar on dropbox
djbrynte
Post by djbrynte »
exo this is the best plug! i mean can i use this plug in FL studio and while playing its playing the sliced stuff in the slice tool?
Because then i can do hedegaard smoke weed vocals. Will show u.
https://www.youtube.com/watch?v=b0UeLSMa_gs
0.40 in this video is example of the voice vocals.
Exo
Post by Exo »
tulamide wrote:It's strange somehow. This as well as all plugins done with Flowstones crash with exactly the same error report when I try to load samples. Since none of my tools, DAWs or non-flowstone.plugins have any issues, I always thought it's a bug with Flowstone. But to be sure about it, I made a drum loop, saved three times as 16 bit int, 24 bit int and 32 bit float.
It doesn't crash for me, but the samples load totally messed up. Like bits of noise but no waveform. Strange cannot be a Flowstone issue because I am doing everything myself (loading and playback)
Exo
Post by Exo »
Strange now I am getting a crash from my test samples! They was working before :?
Exo
Post by Exo »
djbrynte wrote:exo this is the best plug! i mean can i use this plug in FL studio and while playing its playing the sliced stuff in the slice tool?
Yeah maybe, you will have to play around with it :)
Exo
Post by Exo »
Thanks for the samples, I will do some debugging tomorrow and find what is going on. Flowstone might be doing something weird somewhere.
djbrynte
Post by djbrynte »
exo this is nice work. wana try beta when it comes pls :)
Exo
Post by Exo »
Update! Added to first post.
*Fixed the crash when loading wave files.
*Added proper support for loop points, I was reading from the wrong chunk previously now I read from the Sampler Chunk.
*Supports 24bit PCM wave files, also 32bit PCM should be fine but 32bit float doesn't currently work.
TO DO
*Support 32bit float.
*Fully test and confirm loop points work.
*New GUI
*Look into adding REX support.
*Make 'Loop' and 'Reverse' polyphonic too.
*Anything else I forgot.... ;)
My beloved 24 bit int format works! Thank you :D
I then set up a loop in "100bpm_24bit.wav" using Wavosaur. Tested that file with Reaper and Audition. All show the loop's start and end position. Poly Slicer does not. I guess that's one of the cases I talked about, where the loop points are stored as media cues.
Exo
Post by Exo »
tulamide wrote:My beloved 24 bit int format works! Thank you :D
Thanks for testing. Can you share the file for me to test?
Could be they are in the sampler chunk but there is an error in my code. If they are saved as Cue Points then I will of course have to add that back in ;)
